GridIron Nucleo for PREMIERE?
Yes, I read a post from a guy here that made a test and what usualy took almost 3 minutes would take like 25 seconds. It would be amazing if they came out with a version for premiere to...as a matter of fact there's a couple of plugins that are said to be for AE only that I installed on Premiere and they worked.
Yea, I think I read that same post...eventually, I will probably purchase the product; since i'm doing the majority of my rendering via AE, because the lack of batch rendering in PP2.0
You can download a trial on their website. I might just try it too. If this guys equation is right the difference is amazing!
thanks, one. i'm rendering now via AE - testing some output settings...itchin to pull out my cc :(
nucleo
nucleo
rawfa said:
Is there such a thing as a GridIron Nucleo for Adobe Premiere Pro?
http://www.gridironxfactor.com/products/nucleo_overview.asp
Nope it's AE only.
As a side note I'm pretty sure you need multiple processors for Nucleo to even work (it says as much in the system requirements). It says it works with hyperthreaded CPUs but that you won't notice as much.
I have tried it out on my dual core PC, and the render times are faster, both previews and final renders. One file that previously took about 65 seconds went down to about 35. Pretty impressive, and without a doubt worth the $145.
