Anybody shooting green screen? Would like some camera set up suggestions. I just shot some tests today using 30p without any real problems, but it was a lot of guess work. I would like to get some practicals. Besides a well lit green screen, anything else I should know?
As you said, the green screen must be well lit, and as uniformly possible. Your subject needs to be a certain distance from the green screen to avoid green light spill. Good lighting, of course is key (pun intended). You need your basic lighting kit: key, fill and backlight. Backlight being the most important one, because it will better "isolate" your subject from the background and also remove any minor spill bouncing off from the green screen.
Experimentation and practice is important. Most importantly, match your lighting with your intended keyed background.
Once you capture your footage in your computer, depending on your keying software, try upscalling your footage to 4:2:2 (instead of keeping it at DV 4:1:1), or better yet at 4:4:4, you will get better results. I personally use Matrox RTX100 Xtreme, and it upscalles to 4:4:4 automatically when I'm keying. Of course being Matrox/Premiere combo, it doesn't support 24p. :'( But I intend to remedy that soon.
Thanks Flintstone, The lighting and keying I have pretty much under control. I have a good compositor and we are using shake and I have a DP to handle lighting. I'm more concerned on the camera set up. Any suggestion on the best settings for green screen?
If you have your detail up, it'll create false edges that will look artificial against a screened background and will be hard to get rid of. With detail below -4 you start losing data due to the way charges in the CCD work (or so I've read). -4 is the ideal setting usually, but it's too soft for my tastes so I normally run -2. But when I green screen, I bump it back down to -4 to make sure I don't get any false edges.
I just recently finished two days of green screen shooting with the DVX and here is the setup I used.
I had a 12X12 Green Screen, this was the foam like material, I went for this material because the green doesn't bounce off the screen on to the talent as much as using green paper or a muslin type material. The screen cost me $45/day. You will also need (2) Combo Stands and a 12' Pipe to hang the green screen.
Next I used (4) 1K Baby's to light up the green screen. I did a cross lighting pattern so the entire screen was lit even.
Next I took (1) 1K Baby with a minus green gel (purple) and used it for a backlight. The reason for the minus green is that is takes out any green that is bouncing off the screen and onto the talent.
I had my talent 15' away from the green screen. I find it's better to get a larger green screen so then you can have more distance between your talent and the green.
As for lighting on the talent, I used (2) 4' 4bank kino flos. The kino's are great because for someone with light skin I'd used only two of the bulbs per bank. With the talent that was darker skin I'd use all four.
I shot with the F5 settings. (24p Progressive) and I'm keying out the footage in AE 6.0 Pro, using the Keylight plug in.
I have been doing test with the DVX for a couple months now and I have say this is the best approach I have done so far. As for price, the entire package cost me about $400/day.
Exposing the green screen in about half the light used for the main subject will deliver a quite saturated green.(e.g., 100 footcandles on talent 12-15 feet in front, and 50 footcandles as even as possible on green). It works for me. Hope it can help somebody else. I've found that lighting the green screen at the same level as the talent produces a slightly washed-out green that reacts a bit differently...
...not really a camera set-up thing...merely a lighting idea...
sorry for mixing the topics...
[quote author=Egoboy link=board=news;num=1068451865;start=0#9 date=04/30/04 at 18:33:17]
[/quote]
I'm surprised you shot at the F5 setting. Even though are shooting in progressive mode, at the F5 setting, the footage is interlaced. I would suggest shooting real progressive with the F6 setting. You will have much cleaner keys, and less footage to render.
F5 and F6 (assuming they are not changed) are both real progressive formats when shooting 24fps. Again it all depends on what NLE you are using in the end. AFter Effects can render out the NORMAL 2:3 pulldown of NORMAL and create progressive 24 frame media (23.976).
