Green Screen
You might also want to check out the ReflecMedia Chromaflex system. We own two of them and they make doing greenscreen work SO much easier and simpler with less heat, lights and better comfort for the talent.
Not cheap.
Dan
Thanks...for the feed back..and yes i did google but i wanted a recommendation, for a product and source, not just a google pot luck.
thanks puredrifting
I used fabric from walmart ... we sewed three pieces together and pinned it against a wall... total it was about $30 and the greenscreen is about 14 X 12 feet... the keys are easy as well...but then again you can key just about anything with Keylight.
Depending on your size needs and how cheap you want to go, I've had good experiences with green posterboard. If you tape them with green tape, or from behind, the seams aren't noticable. On the other end of the spectrum, I have a 6'x7' collapsable green screen from Botero, and it works great! ($70 at B&H).
Ebay... That's where i got mine and I believe it was Amvona actually that sold it to me in an auction. It works fine. There are others though that look good too.
