Greatest Director Portrait Ever!
Batutta
Major Contributor
Orson Welles on The Chimes at Midnight--
Damnedest thing...:undecided
Whenever I try to put Cameron onto the body, I just can't do it, nothing will make the head smaller.:cry:
Hmm.......:huh:
damn what a powerful image, anyone want to take a crack at what the lighting setup was?
My guess is natural light with a bounce-card or light wall/surface behind the photographer. The brick wall behind the shaft of light is softly illuminated by light reflected off the dust/smoke in the shaft... with a gradual fall-off also from the same bounced light that's hitting Wells.
The shot itself was almost certainly taken with "standard" black and white film... which has a much higher latitude then digital, and a stop+ better DR performance then color film... which is (depending on when you read this)... probably a couple stops better then digital... hence the "awe" at the great lighting.
If you happened to be standing around with a film cam... it would probably have been easy :)
