Loki
Oki... I have been trying to teach myself all about when to use different lenses.. and the differences between digital and film lenses..
Someone correct me if I am wrong here, I am most likely not going to have access to a DP with any sort of knowledge in this area. (My DP is a fellow student.. so still learning, with much less knowledge than myself..)
Digital Cameras/Camcorders require a lens with a much smaller focal length to deliver the equivalent of a 35mm lens because of the small CCD size.. am I correct?
the DVX for instance, uses 1/3" CCDs, so technically if I were using a DVX that magically had 2/3" Chips, I would see more picture than what the 1/3" chips produce just because more of the projected light from the lens is hitting the CCD... ?
according to Panasonic the 4.5 Focal Length of the Leica-Dicomar lens is equivalent to a 32.5mm 35mm lens... because of the small sensor area, cropping occurs on the image, cropping that you will never actually see though..
I hope this makes sense and is correct. I want to rent the the P+S Technik 35mm Adapter and use the 35mm lenses from my school on it. So I am trying to get my head around the types of lenses I will need based on my sets/shots.
35mm needs bigger focal lengths than a miniDV cam to produce the same field of view.
Is my understanding up to snuff? or am I off?
