GPU for Vegas 6d
...and DVI is just the means to connect your card to your monitor using a digital rather than analogue signal...won't help Vegas per se.
so dvi would offer no advantage to the old analog pin head?
unless of course u intend on running GPU intensive plugins such as magic bullet 2 or ProDad vitascene
All you need is the dual DVI if you want to plug in dual monitors with DVI connections, as stated above.
I find the 7600GT to be the best deal in terms of bang for your buck. It is not a crappy card by any means, and the price is affordable at $100. Lower than that you'll still pay a lot and get much less, then, higher than that you'll need to spend about $200 to get your money's worth again. IMO.
But, all you need is a card with a portion of the performance of the 7600GT to run monitors.
