We have had plenty of shots ruined by auto exposure on the GoPro/Phantom, especially when tilting, so I started looking around for exposure lock ideas and actually found something that works.
https://github.com/KonradIT/autoexechack
Click the "Download ZIP" button and you will get all the hacks (I didn't try the single download links).
Then just find the Video Exposure Lock .ash file and copy/paste it to the root of your SD card. (Usual disclaimers apply for adding hacks to a camera, can brick etc)
To use it on a Phantom with a H3-2D, this is the only way I could get it to work:
Switch copter off
Switch GoPro on (it locks expsoure as soon as it switches on, so point it where you want to lock)
Switch copter on
Hit record.
To reset the expsoure, you have to repeat the above steps. To go back to auto mode, delete the file on the root or insert another SD card.
My theory as to why you have to power down the copter is that, with the battery on, the GoPro never does a proper power down cycle because of the power supplied by the gimbal.
For me, it has been a godsend and the guy should be getting similar recognition to ML and Vitaly.. Especially as he is only 15 years old! Insane
Switch copter off
Switch copter on
Hit record.
