Good QTVR creating software?
snodart
Hi all,
I'm selling a piece of property for my father-in-law. I'm going to put together a small web page with all the specifics of the lot, some stills, and a QTVR movie of the lot's view. I've been rummaging through the various pieces of software to stitch panoramas together and to convert the panos to QTVR movies. I'm I little baffled as to which software to choose. I've tried Calico, cubic converter, PTMac, and VR Worx is doing some stitching as I type.
I am on Mac with leopard. Anybody have any recomendations for software? VR Worx so far seems to be the most "all-in-one" and reviews of it seem to be pretty good. Calico did a pretty rough job of stitching the images together, but I did not make any adjustments to the images prior to stitching them. PTMac seems to be a very manual process, but I haven't finished the pano to see the results yet.
I used my Rebel with a 50mm lens. I ballanced to daylight and only adjusted shutter speed with each shot to maintain a constant exposure throughout all of the images. I don't have a pano head, but since the pano is all distant landscape (minus a few close trees), I was hoping to get away with being off from the nodal point by a bit... for a test run anyway. I'm thinking that I could make a decent DIY pano head if need be. Any tips in the actual taking of the pano would be helpful as well.
Thanks!
find one shutter speed that suits every shot and don't change it. If you adjust it through out the pics you will have to manually blend it together later.
Just FYI for future searchers. I ended up using Photoshop CS2's photomerge. Worked like a champ. It gives the option to save the pano with each image as a layer for manual fine tunning or you can export the final pano as a single layer and let photomerge work the magic. After using photomerge, I exported the pano from Photoshop as a TIFF and turned it into a QTVR with PTMac 4.1.
Link to QTVR: http://snodart.com/snodpublic/DonLot/Pano6.mov
