Good deal on MacPro Ram...or not?!?
It's (2) 4gb Sticks so I'd be balanced after removing a 1gb stick and installing those in the 2 vacant ports, right?
A thousand apologies, I just referred to your macpro system specs, as far I can see this RAM will be fine, its actually faster than the machine spec. And yes just pull out the 1 G stick and insert these guys. You may want to wait until someone else confirms my thoughts.
I might add some specify only buying mac ram with the fitted heatsinks but I have seen macs run on PC ram
No prob : ) Thanks for the reply. Just got off the phone with Kingston, though. No-can-do.
They said the 1600ghz is too fast for Apple's finicky system.
Darn. So close.
You learn, I did not think faster RAM would be a problem wonder what the issues are too fast for the processor to read...
