I have three Giant Squid omni lavs and they all work with my H4n so long as plugin power is enabled in the menus and they are connected to the 3.5mm socket on the rear of the H4n.
Interestingly they also work when connected to an XLR socket on the H4n if I first connect a Sennheiser CL100 XLR to mini jack cable to the H4n then use a connector to connect the lav cable to the senny cable IF I enable phanton power in the H4n :- ) That Sennheiser cable is one that comes with the G3 wireless kit.
Do you have a camera you could test the lav with instead of the H4n? It should work when direct into a 5DII and most consumer camcorders with 3.5mm sockets.
Pete
