Hello people. Over the past year I have started to do these occasional edits where I am dealing with greenscreen/compositing. Simple talking head, sitting or standing, talking against a screen.
I would like to be able to pull better keys. Problems I'm having (not always at the same time, across different shoots) are jagged edges when matte is choked down enough for green to be gone, slight black or white outline usually around shoulders/body that can't be gotten rid of without degradation to everything else, generally edge issues.
These are shot by a professional crew with an EX-1 (sorry, not with the Ki whatever that allows 4:2:2, just the stock CODEC via SxS cards, not my call).
I've tried several keying plugins (trying to stay in FCP rather than deal with After Effects/Motion), like PHYX, Keylight, DVMatte, and Primatte RT. I've gotten OK results with all of them but zoomed at 200% I can see the issues I describe, and they're slightly visible even at 100% so I think more can be done.
I've read around and seen the advice that a) most tools will work, it's more about the methodology, and b) you generally can't get a good key in one pass/instance of a plugin; it's all about multiple instances doing different tasks, and multiple mattes composited into one.
These are (so far) corporate videos for the web/computer/intranet viewing, with tight deadlines, so I really don't want to get into multiple mattes and all that unless it's way less complicated and time consuming than it sounds. However, two passes of a keying plugin I can work with.
Can anyone advise, using the plugins mentioned above, or stock tools in FCP? Thanks. Not having luck finding really good tutorials online/youtube. One tutorial mentioned using two layers of the original video, one on bottom has the green desaturated and is combined with the keyed layer to somehow make the key better. . .not sure how to do that in FCP.
Thanks.
Thanks.
