Getting an audio reference track in the ALEXA
ronin99
Hi,
I'd like to get a scratch track into the Arri Alexa.
It has a 5 pin xlr connector and I thought it would be as simple as getting a 5 pin to 3 pin adapter and then plugging in a mic.
However, I was told because it is a line level input that it is more complicated than that?
This is what the manual says "2-channel analog line-level audio can be fed to the camera via the 5-pin
XLR connector located at the front of the camera on the camera-right side."
I'm not an audio guy, so I'm not sure what is needed, but all I want is a reference track in the footage.
The only difference is the 5 pin connector is two (balanced) channels. I don't recall the exact pin config but channel 1 (L) could be pins 2&3 plus and minus and channel 2 (R) plus and minus on pins 4&5; Pin 1 is common shield (ground). The Alexa certainly does have better audio quality and hardware than the infamous but popular REDs. I don't know about the latest RED 'Dragon' if that's what they call it
