Loki
I have been searching the FCP 4.5HD help file for a while and have not been able to find what I am looking for.
Does anyone know how the rendering in Final Cut Pro works?
I have noticed an image degradation when I apply a widescren crop, and a 3-Way Colour Corrector.
I am mainly wondering if the rendering is culmulative? Is final cut decompressing the DV frame, applying filter 1, then when I apply filter 2 is it using that already re-encode frame to decompress and apply filter 2? or does it always decompress from the source file first then layer in all the applied effects on top?
My inkling is that it is doing in the latter of the two, which from a programming point of view makes far more sense to keep the quality level high.
Could it be that the crop filter just throws the DCT compression off a lot to make the image worse in it's newer "non" standard frame size?
Reasons for asking, I was thinking of re-capturing the final finish film, then doing all the colour effects etc... using the uncompressed 10bit capture. (And yes, I realize that it still has the DV compression from the Tape).
I just want to keep the cleanest and clearest image possible.
Any thoughts on this query?
