G2 Sennheiser Wireless into wireless speaker
allygirl
I have a G2 Sennheiser Wireless mic set . I want to use it as a PA system and connect the receiver to a wirless amplified speaker set . It looks like the receiver has a 3.5 mini jack out . - and the amplified speaker has a mini 3.5 jack in - any reasons why this will not work ?
cheers
Interface
Interface
Sounds pretty close, but the devil is always in the details. As you know, your Sennheiser G2 is mono - we'll assume your amp is the same, otherwise if the jack is a TRS you won't hear anything on one channel. Also, we'll assume the amp uses line level (not mic level) input voltage your Sennheiser G2 is outputting - otherwise you'll need to pad down the signal using the "AF Out" option on your Senn G2 (From Line Level to Mic Level)
Good luck, Michael
