FTP server software?
morten
anyone know of some good FTP server software? I'm having major problems with i Linksys WRT350N router and BulletProof
mor10
I'm confused. Your router and ftp client software are giving you trouble, so you need new server software?
I used to use something back in the day called...i think it was called G6. Not 100% sure on that. it was G and then a number. Worked extremely well.
As I suspected the problem I had was caused by an incompatibility between BulletProof FTP Server and the router. I switched to FileZilla Server and now everything is working fine.
mor10
Do you have port 20 blocked?
nope - BulletProof didn't even work when I put the server computer in the DMZ and opened all the ports. some sort of conflict with the router that a lot of people are experiencing. But all other FTP Server software works fine with the exact same settings. too bad for BulletProof who will not be getting my money.
mor10
