FS700 bobbing problem with glidecam
Neutral
I used to fly my FS700 on the glidecam HD2000 all the time and for every shoot and got tones of great footage. This summer I noticed this ugly jittering/bobbing showing up on my footage when I used the glidecam. I figured maybe my glider was getting old, I've used it for years and it was missing screws and knobs. Everyone told me the HD4000 is better suited for the FS700 anyway so I bought one and took it out for some test shots today and I have the same problem. It almost looks worse!
I posted a link to an example of a test shot I did where you can see it jittering. Does anyone know what I'm doing wrong? I know how to walk properly with a glider and I don't think I'm stacking too much weight. This shot was just the camera body+lens+anamorphic adapter (slr magic anamorphot).
Any help or advice would be greatly appreciated.
https://www.youtube.com/watch?v=xFQwDRzvcEE&feature=youtu.be
Can't see a problem viewing on my phone
jiytter is usually problems in the system eg lens wobbling in adapter or camera not tied down hard - I'd guess lens adapter issues
bobbing is poor walking by the operator that is corrected by practice
If you view it on a computer the problem is very obvious, there's constant visible vertical shaking. I think maybe "shaking" and "bobbing" aren't the right words. It's more like vibrations. I have 3 weights on each side of the wing extenders. I just weighed my set up and it's around 6pounds. The glidecam HD4000 supports 4 to 10 pounds so I should be good there.
I have plenty of practice with glidecams. Like I said I've shot big projects with glidecams for a few years now and got excellent results. I don't know whats going on here.
I watched your video - I can't think of anything on a flycam rig that would even be able to move that quickly. I think the problem is coming from your camera.
Do you have image stabalisation on for the lens? This can fight against smooth camera moves on occassion.
I don't have image stabilization on these lenses. They are nikkor ai-s series lenses. I am using cheap adapters and a speed booster. I'll try a shake test in the morning. Thanks for the suggestions guys, this is really frustrating :/
So I've been doing tests all afternoon.
The guy I bought the glidecam from had the same manfrotto mount I use mounted on top of the cheeseplate. But his was elevated about an inch with a big bolt and washer (Im assuming because that tightening notch on those mounts are annoying). Anything I tested with that set up got the vibrations. I stripped everything down and just layed the fs700 on the cheese plate with a screw, no quick release. And everything is butter smooth.
Now what I find strange: When using my FS700 on my glidecam HD2000 this summer I used the manfrotto plate but not elevated and I was getting those shakes as well. So is this occuring simply because the shape of the FS700 is long and having it sit and balanced on something small like a quick release plate is magnifiying the vibrations that come with walk with a stabilizer? This kind of stuff drives me insane when I can't figure out whats causing the issue haha. And as of right now my solution is strip everything down and go bare bones on the glidecam. This is going to be a real pain in the ass on set not being able to use quick release plates when going from stabilizer to tripod or something :/
The problem with (many) quick release plates is you can't get them tightened down all the way. There's not enough room to turn the level far enough. With the weight of the FS700 w/lens, any slight play will turn into unwanted movement.
