Lesson Learned!
1. Don't repair clips with the FS100 (or back the originals up first)
2. Use P2 cards if it's important.
3. Conclusion
1. Focus advised me to follow the steps below to repair clips due to
the Avid import issue "Audio:
MM_insufficient_Media()
player version of duration is longer than actual"
Don't do it if you filmed at 720/24p with the firestore set to PN!
FS-100 V3.0 has some improved P2 Repair Clip (eliminates "orphaned" files). As outlined in the release notes.
Clip Repair Procedure.
1) Upgrade the FS-100 to V3.0
2) Note the name of the clip reporting the error.
3) Find the clip number that corresponds to the problem clip using UTILITIES->FILE NAME.
4) Select UTILITIES->REPAIR CLIP.
5) NOTE: this will move and rename the clip into a new folder. Both the new folder and the clip will have the current time and date.
6) Select UTILITIES->ORGANIZE P2.
7) The clip will now have a different name assigned to it.
8) Use the AVID “Media Tools” option to bring the file into your timeline.
9) Should be able to pull into FCP as well.
I shot footage for an EPK which I knew the FS100 would have audio sync
errors later when I brought it into Avid. I received the instructions above via
email and decided to test it on one clip.
I set the project up in AVID at 720/23.96 and pulled the clip in to verify that
there was an audio sync error. Then I disconnected the FS100, found the clip
in error and chose "Repair Clip" on the FS100 then "Organize P2".
When I attempted to bring the media back into my 23.96 project I received
an error stating that the frame rate of 59.94 does not match the current
project frame rate of 23.96.
So I created a new project at 59.94 and brought the clip in (using the media
tool). The clip came out under cranked but the audio was normal but half of
the original clip was missing. So I had fast video, normal audio and missing
audio and footage from the original file before using the "improved clip repair
features". Now my shot is gone forever.
Nice work Focus.
2. I'll Use P2 cards if it's a money shot.
I've been hearing back and forth talk about the FS100 vs P2. This is not to
try and take part in that, but to share my experiences.
I shot an entire day with the HVX200 set to 480/60i without any issues with
the FS-100. Later that night I was filming in 720/24p with the FS100 in PN
mode. The FS100 continually locked up.
I checked the firewire cable connections. I used a different firewire cable etc..
The unit was strapped to a DVRigPro with one velcro strap. It was right on my
shoulder where there wasn't much movement. It was an indoor shot, standing
still yet the unit kept locking up. So looking like the idiot, I kept rebooting the
FS100 (by holding the power button a few seconds and letting go).
In the HVX viewer I kept seeing a red symbol that looked like a tape with an x
through it. I have never seen this symbol before. While the record was
enabled this symbol would appear whenever the FS100 was locked up.
3. I give up on the FS100!
After a year of battling with Focus issues I'm going with the P2 cards
regardless of how expensive they are. I'm tired of waiting for upgrades and
fixes, loss of footage, upredictable outcomes, Avid import issues with audio
sync errors (which was fixed in Aug or 2006 and is now back), lockups and
restarts, clip repairs or clip destruction.
I'd rather worry about getting the right shot and not wether it's going to get
recorded or not.
However, Focus did tell me that these issues will be addressed in 3.1.
While they are working on that, I'll be working on buying more P2 cards.
3. Conclusion
Nice work Focus.
recorded or not.
