FS-100 Spanned Clips Question
hoopsking
How come some clips we record are Spanned and may go on for 8 minutes and other clips are split after 2 min 18 seconds?
Are they all in the same recording format? The FS-100 has a maximum file size of 2GB per clip, and that is reached at different times depending on the codec and framerate you use.
All your clips will be 2 min 18 sec on the FS-100. FCP spans clips that were all part of the same shot. FCP is sort of flakey at the moment with the clip spanning, so don't worry if not all clips that should be spanned aren't.
