FS-100 owners with Steadicam-like Stablilizer rigs
steditrak
Anyone using a Sony FS-100 with the stock 18-200mm lens on a Steadicam-like stabilizer knows how the telescoping or extruding elements of this lens immediately affects the pitch balance of your rig, once you zoom in for a tight shot.
Have you seen or heard of a solution for this?
If not, has anyone at least experienced this particular issue first hand?
gimbal based stabilizers work on very, very, very precarious margins of balance. simply moving a cable can throw them off. in my experience compensating for something like this is simply going to be an issue of practice
You can't just refocus... even with a zoom lens with internal zoom elements like the Canon 24-70 II or 70-200 it will throw off the balance and you'd need to re-balance.
This is from my personal experience with the Steadicam Pilot and the FS100, but I suppose any gimbel stabilizers will work just the same as WGZN says.
OK, so it's not my imagination. Other people beside myself had the same experience.
Here's the good news: I solved the problem.
My rig before modifications:
After:
My rig in perfect dynamic balance:
https://www.youtube.com/watch?v=_RCs7XOxwys
My solution for extruding zoom lens elements:
Go ahead and build one for yourself. It works like a charm.
If you have any questions, feel free to ask.
After:
Why go thru all that BS when you can trim the camera back on the stage.... Rather than creating a "solution" to a problem the doesn't really exist learn to use the gear you have
