DelRio Well-known member Dec 8, 2006 #1 Can anyone point me in the right direction to buy the extended life battery for the FS-100. Thanks
N nsoltz Veteran Dec 8, 2006 #2 Call Focus or check their web site. I use a Tekkeon MP3400 very successfully with the FS-100. Check it out www.tekkeon.com Ned Soltz
M Matthew McEwen Active member Dec 8, 2006 #3 The FS-100 high capacity battery is available on the Focus webstore as well as through FS-100 dealers. http://www.focusinfo.com/webstore/catalog.asp?type=45
bbalser Veteran Dec 8, 2006 #4 I use the high capacity battery from Focus, and the DVXuser.com battery for my HVX. The Focus out lasts the DVXuser.com battery by a lot. Thus, I never worry about the FS, just the HVX.
DelRio Well-known member Dec 9, 2006 #5 Hmmmm. is the High cap battery from focus the same size as the reg or is it oversized?
bbalser Veteran Dec 10, 2006 #7 It's slightly thicker, very slightly thicker, and you can't tell any weight difference (I mean, the thing is light as a feather to start with).
