iamlance
Hey, I recently purchased a used Arri 300w light for very cheap (like $124 cheap), but only because there were a couple problems with it. Most are easy fixes or only affect the aesthetics.
The biggest issue is the fresnel lens is cracked down the middle. The seller did say it didn't change the light much, but I am skeptical.
I won't have another Arri to compare it to, so what should I be looking out for in terms of quality loss? I am figuring out whether I need to replace it or not.
Also, the Arri light is the old version, not the plus version. What exactly is the difference between the two?
Is it just the internals that are different, or was the whole structure changed, so screws/lenses are not compatible between the two?
I am having trouble finding the old style lens and am wondering if the newer lens will work. http://www.filmandvideolighting.com/ar300plfrlen.html
EDIT:
http://www.lightsonretail.com/Merch...ode=ARRI-L4_79224_E&Category_Code=Arri-Lenses
http://www.lightsonretail.com/Merch...ode=ARRI-L4_79207_E&Category_Code=Arri-Lenses
The prices between these two lenses are very different, and as the description mentions a different mounting method, can I make it work?
EDIT:
