Free-run Timecode
epicedium
Which lower-end (i.e. not sound devices) CF recorders will free-run internal timecode? i.e., no t/c in/out necessary, just the ability to free run time of day t/c.
The Tascam HD-P2 can also internally generate a free-run TC, again, it's real limitation is the lack of of a TC out port.
Phil
actually, I'm doing it as I type this - you can set the tc to run however you want - you just can't share it with any other device.
Free-run-you just set the clock source to internal, then set framerate, pull up/down option, etc.
Again, the only thing you can't do is get the TC out of the recorder. (And yes, that is a STUPID thing that they left out!)
Phil
