Nicholas Natteau
In Apple Motion, I used to use the "frame" command when I created a camera to quickly frame objects in my simulated 3D scenes.
Does AE have a similar shortcut command so that when you create a 3D scene with camera you can quickly have the camera move from framing one object to another to another. For example:
Let's say you wanted to move your AE camera through space from one photo to another to another, is there a quick "frame object" command so you don't have to play with X,Y,Z until you have the objects framed perfectly. This would require a lot more time to do manually.
