Frameserve project
buhce
Hello,
Anyone know if it's possible to frameserve a project from vegas to some other encoder, 'cause I'm having a terrible time getting vegas (8 or 9) to render any project over 3 minutes.
I would tackle the render problem before I looked at frameserving to another program.
What kind of project is it? What kind of footage is it? What are you trying to render to?
Need as much detail as possible.
It doesn't seem to matter what footage it is. I've tried lots of different footage- mainly Sony Ex1 footage(tried both .mxf and original .mp4). I'll get the 'out of memory' error when rendering 8-bit (sometimes it just freezes at variety of percentages)and it'll just crash with an unknown problem when rendering in 32-bit. (or with an error like that in the quote)
I am mainly rendering to .wmv 1080p but have tried 720p. Also tried other codecs mainconceptand the Sony .mp4 and they were working for a couple of renders, then it just began again. Occasionaly with 32-bit I'll get some error code. I know I'm not out of memory 'cause I have 12Gb and the application doesn't even come close to using it all before it crashes. In the past I've had to start rendering smaller clips and reseeding them back into a new project - shouldn't have to do this. Plus sometimes even that crashes.
Sony Vegas Pro 8.0
Version 8.0c (Build 260)
Exception 0xC0000005 (access violation) READ:0x61D1000 IP:0x74F1500A
In Module 'MSVCR80.dll' at Address 0x74F00000 + 0x1500A
Thread: ProgMan ID=0xE44 Stack=0x5E4F000-0x5E50000
Registers:
EAX=06473000 CS=0023 EIP=74f1500a EFLGS=00010212
EBX=00000000 SS=002b ESP=05e4f4ec EBP=05e4f4f4
ECX=000a8800 DS=002b ESI=061d1000 FS=0053
EDX=00000000 ES=002b EDI=6bae10a8 GS=002b
Bytes at CS:EIP:
74F1500A: F3 A5 FF 24 95 24 51 F1 ...: 74 90 8B C7 BA 03 00 00 t.......
Stack Dump:
05E4F4EC: 00000000
05E4F4F0: 3A1A4F58 3A0C0000 + E4F58
05E4F4F4: 05E4F868 05D50000 + FF868
05E4F4F8: 2EF8755A 2EF70000 + 1755A (wmfplug3.dll)
05E4F4FC: 6BAE00A8 6BAE0000 + A8
05E4F500: 061D0000 061D0000 + 0
05E4F504: 002A3000
05E4F508: 2B89D82C 2B770000 + 12D82C
05E4F50C: 1AD05DA0 19F20000 + DE5DA0
05E4F510: 1A8B3224 19F20000 + 993224
05E4F514: 1A8B31F0 19F20000 + 9931F0
05E4F518: 33564D57 33560000 + 4D57
05E4F51C: 008D11D8 00400000 + 4D11D8 (vegas80.exe)
05E4F520: 00000001
05E4F524: 00000007
05E4F528: 00000500
> 05E4F55C: 00900000 00400000 + 500000 (vegas80.exe)
05E4F560: 00004E20
05E4F564: 02800000 02210000 + 5F0000
05E4F568: 00000064
05E4F56C: 00000000
> 05E4F5F8: 77B52C10 77AF0000 + 62C10 (ntdll.dll)
> 05E4F628: 196D9F97 19670000 + 69F97 (sftrkfx1.dll)
> 05E4F62C: 1975CF44 19670000 + ECF44 (sftrkfx1.dll)
> 05E4F630: 1975CF48 19670000 + ECF48 (sftrkfx1.dll)
> 05E4F63C: 00779596 00400000 + 379596 (vegas80.exe)
05E4F640: 00000008
05E4F644: 14564858 14010000 + 554858
05E4F648: 147162AC 14010000 + 7062AC
05E4F64C: 00000000
> 05E4F65C: 0077A578 00400000 + 37A578 (vegas80.exe)
05E4F660: 00000000
> 05E4F664: 0077A5B5 00400000 + 37A5B5 (vegas80.exe)
05E4F668: 058C08E8 05840000 + 808E8
05E4F66C: 058C08E0 05840000 + 808E0
05E4F670: 058C08E8 05840000 + 808E8
05E4F674: 00000000
> 05E4F680: 01B47F38 01A90000 + B7F38 (vegas80k.dll)
05E4FFF0: 00000000
05E4FFF4: 00527950 00400000 + 127950 (vegas80.exe)
05E4FFF8: 00AE7AB0 00400000 + 6E7AB0 (vegas80.exe)
05E4FFFC: 00000000
That's what I got the last time I used 32-bit project at either 1080p or 720p.
Oh yeah I use Magic Bullet Looks also. It's not my setup 'cause I have tried it on my other computers and the same thing happens at various points in the render. It's not the footage either - this happens with every project. I'm at a loose end. Tried adjusting render threads and Dynamic preview. Tried going through each option in the preferences and switching them off, tried getting Sony to fix the problem, tried getting Red Giant to fix the problem.No dice.
You're saying that any project with any kind of footage will not render, and that's true on multiple computers running Vegas? That doesn't seem right at all.
Try removing the MB stuff and see if it works.
Any HD footage when using Magic Bullet mainly.
Just happened again:
Problem Description
Application Name: Vegas Pro
Application Version: Version 9.0a (Build 704)
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.1_none_e163563597edeada\MSVCR90.dll
Fault Address: 0x6EA1AB1A
Fault Offset: 0x0003AB1A
Fault Process Details
Process Path: C:\Program Files (x86)\Sony\Vegas Pro 9.0\vegas90.exe
Process Version: Version 9.0a (Build 704)
Process Description: Vegas Pro
Process Image Date: 2009-07-17 (Fri Jul 17) 09:13:40
it happens on my 32bit systems too.
I've had it crash on me before without the MBL.At the moment ( on this project) it seems to be crashing on a fade out where there is no footage or it's faded to black. I might try some black video.
I was hoping 9 would fix this.
Hi Buhce,
Couple of months ago, I tried to frameserve vegas 8.0C to use external encoder such CCE SP2 or Procoder 3, I got no reply from this thread. After researching some information , now I know how to do it.
1. Installed Debugmode frameserver ( download from website, google it )
2. go to Vegas and render as Debugmode frameserver.AVI in drop down menu, let it run, but do not stop, just minimize it ( very important do not stop it )
3. then run external encoder ( CCE Sp2 or any encoder ) it will be linked to vegas files and render out as any format or Mpeg2 ready to burn for DVD.
Hope it will help you
Billy
buhce:
Did you specify Stereo or Surround 5.1 sound? I encounter the same kinds of errors when I render Full HD (any format) with Surround sound, but I can render ok when I specify stereo sound.
NOt that I am using Vegas Movie Studio, not Pro, but I'm gessing the rendering components are the same.
I'm beginning to suspect the problem lies with the Microsoft Visual C++ runtime library, and not Vegas itself. There are several versions of the VC++ runtime out there and I'm guessing Vegas is dependent on a particular version, which is now obsolete. It's posible that Windows Update replaced some parts of this and that, in turn, is what's causing Vegas to crash.
All this is just supposition so far, but after I installed Vegas MS on a fairly clean laptop that had no VC++ at all it rendered fine. This is very reminiscent of the old "DLL Hell" problems in earlier versions of Windows, and, unfortunately, is very difficult to resolve -- if I am correct.
buhce:
I've thought that it's perhaps a windows problem also. Does your Vegas MS still render fine and what version of windows were you using?
Regarding audio. I checked it and I'm rendering stereo.
Problem Solved!!
I reset the memory flags using CFF explorer of the following:
vegas80.exe
wmfplug4
(and other codec .dll files)
open the program
goto file\open
then find the file... in this case it would be Vegas.exe
On the left side you'll see "NT HEADER".... "DOS HEADER"... etc
Highlight "FILE HEADER" under "NT HEADER"
On the right side you'll see a chart and in the bottom right corner you will see "CLICK HERE"
Click on that and a check box menu system will open.
Scroll down the menu list until you see "app can handle > than 2gig address space" and check that.
Save the file and close
remember to run the program as admin
I've not had a crash since
