veidog
Hello. When I grab stills from my DVX footage in vegas 5 the grabs come out blurry. As I scrub through the time line to select the frame I want, viewing the preview window (set to best full), every object that has motion looks blurry and every 4th frame has interlace lines which renders that frame useless for a grab. This is using the default NTSC DV 24p Widescreen (720x480, 23.976 fps) template. However when I switch to the NTSC DV Widescreen (720x480, 29.970 fps) template the motion problem goes away but the lines are still there every 4th frame. The original footage was shot in 24pa. Am I doing something wrong here? Thanks, mark
