greeches Veteran Dec 9, 2004 #1 I'd like to export frames to photoshop then import them back into premiere. To get effects such as the bullet hits in the Noir clips... Any ideas how to do this?
S Shaw Veteran Dec 9, 2004 #2 Re: Frame export import possible? yep, go to file -> export you should have the option of exporting the video as a sequence of frames that you can edit then reimport.
B BLUESPIDER DVXuser Ninja Dec 10, 2004 #3 Re: Frame export import possible? Select the frame you want and hit Ctrl+Shift+M and save. You can also export as filmstips. Export and change AVI to filmstrip.
