Frame Blend
LightupChoiceFry
Hi everyone,
So I figured my issue out in regards to my exports including jilts and additional frames.
I have a question, is the frame blend option normally used by you? I know that it's needed if two clips running next to one another have different settings. Everyone of my clips in my timeline are the same (frame rate, quality, camera, aspect ratio, etc). But I know that CS4.2.1 automatically has frame blend checked. Is it preferred as a safety to keep it checked ,or to uncheck it when in my situation, it's not needed? Or does it help with the flow and everything to have it checked?
Frame Blend, even when on, only comes into play when the frame rate differs from what is actually in the file, like when you use slow motion. If the clip is playing at the same rate it was recorded at, Frame Blend won't have any effect, even when turned on.
