Forum Upgrades
Jarred Land
President/Founder
Staff member
Hey everyone, adding some new features to the forum today, let me know what problems you have. shouldnt be too many visual changes, except that now threads you have viewed go a little darker white than the threads you havnt seen. Things are really quick.. go try and do a quick reply somewhere to see what im talking about.
Was the style sheet changed? The fonts look different. Maybe it's just the bg colour that makes it seem so.
Look cool though.
Cheers,
Chris
Jarred - When you modify a previous post the text shows as html code. Previously the code was hidden. Now you're able to see the code and if you make changes (ex: enter "breaks") the new text isn't formatted. Can't explain it. But try to edit your original post and you'll see. Try adding some line breaks in the middle of your paragraph.
Everything else looks good.
I agree the names are a little on the big side, but other then that everything looks good... and I'd just like to say thanks again for such a tight forum setup. It was already so good I'm blown away that you keep trying to make it better.
Okay WOW I like the new edit box. I just got goosebumps.
Regarding that I often use too many words to say something (yeah personal problem) and I'll read my post and fix spellings or edit it down... I'd like to have a little more time to do an edit before the post SHOWS that I had to do one... if possible.
Advanced mode doesn't work... can't post smileys, links, pics or change font/paragraphs :(
edit: ok, smileys work, when you type 'em in manually
Basically all the post format options aren't working. Strange. Sorry can't provide any suggestions on fixes. I only know a little PHP. Frizzle Fry knows alot!!!
Good luck.
I cant see the main banner on the main page anymore. Just the advertisement banners in the upper right.
yeah sorry i just woke up.. was up till god knows last night, so i will start to get on things..
there is a spell check, its just on a different part of the box, its a little button in the right top corner of the advanced thing.
