markblasco
I put together a video in Premier that is about 7 minutes long. I did all of the edits, and now I'm ready to do some color correction and effects.
I opened up After Effects and imported my Premiere Pro Project (I did not use dynamic link, since I need to color correct each clip separately). All of the clips opened into new layers in After Effects, which is great.
OK, now for the problem. I saved the After Effects project, and closed it. When I try to reopen the project, all of the footage is missing, and replaced with color bars.
I tried several times to import a premiere project into After Effects, and every time, it is fine until I save it and leave the program, but once I try to open it again, it can't find any of the footage.
I also tried to render it before closing the project, and it renders with color bars replacing all of the video footage.
Can anyone tell me what I am doing wrong here? It seems like I am doing things right, since the project seems to work fine when I create it, but as soon as I close it or try to render it, it cannot find any of the footage.
CS4 Production suite on an i7 XP machine with 6 gigs of ram. Everything is running on the machine, no networked drives (I have one drive for the OS, one for the media files, and one for audio samples and scratch disk). The files are all MTS (AVCHD) files. I'm updated to AFX 9.0.2
I also now tried taking individual clips in premiere and right clicking, and replacing them with after effects. It pulled them in, and I applied some effects. They linked between Premiere Pro and After Effects fine, until I saved both files and closed them. When I reopened premiere, I now get the color bars replacing all of the after effects clips.
What is interesting is that I have also imported an after effects file which has no video (it is an animated title), and that one stays linked even after closing. The only difference there (other than it not having any video) is that I created that animation in after effects and later imported it, instead of pulling it first from premiere.
If someone has an idea of how to fix this, I would really appreciate it. As of right now, I really can't use After Effects for color correction and stabilization, which is what I need it to do for this project.
