how are the cavision 15mm rods and how does it compare to the chrosziel 15mm rods? is the cavision rods compatible w/ the chrosziel follow focus system?
The cavision rods are carbon fiber, and are compatible with the chrosziel. Here is the way it works, most rod systems are cross compatible, the measurements are 15mm rods that are 60mm center to center, if these numbers are the same then you have nothing to worry about. There are other rail systems for larger film cameras but for the most part we in the mini-dv format go with the above measurments. Hope this helps.
