Hello,
I own a Letus Ultimate with an EX1. I'm confused about the fact that after setting up the adapter on the camera and focusing on the GG I used the peaking function of the camera to check the area that is in focus and the Peaking pattern was not filling the entire image. Shouldn't the peaking pattern fill the screen almost completely if the image has edge to edge sharpness. The pattern that i'm getting is that the peaking pattern if mostly concentrated in the center of the images and starts to fade at the edges. The pattern also starts to fade completely when I start closing the iris on the camera. At about 5.6 it fades pretty hard.
The adapter GG fills my screen at about Z69 setting on the camera. Probably the peaking would fill my entire screen area at longer zoom settings (almost fully zoomed) but this would not be normal working condition. I usually set my zoom to about Z75-80 to avoid corner vignneting.
Another effect that I observed while using it is that with wider Zeiss PL mounts lenses (lower than 35mm) I cannot see the rectangular shape of the adapter window, instead it is rounded at the edges. As a consequence I have to zoom in even further to avoid vignetting (Z85) . Is this normal ?
Thanks! I'll post some photos to illsutrate what i'm talking about. ( I usually get a bigger peaking pattern now as this was an old photo and I don't remeber the camera settings, I guess the iris was stopped down a bit).
