Kendo556
hey everyone
so here is my issue i was shooting a cam test the other day on an ARRI S 16MM camera i used two different lenses a 12 mm-120 mm zoom lens, and a 5.9mm fixed focus lens. my issue is that on wide shots with both lenses i'm getting soft focus i'm measure for focus as well.
now i'm thinking its either my lenses are not calibrated or i measured my focus wrong. but then i started thinking that the 5.9 mm wide angle lens is a fixed focus and from my knowledge shouldnt that be in focus? so then i was wondering if my camera has a depth of focus problem
12mm-120mm lens F2.8 24fps
Here is the first shot notice the letters on the slate are soft as well as the whole frame itself
same thing soft focus on the overall image
these next two shots are shot on using the 5.9mm wide angle lens with fixed focus
5.9mm wide angle lens fixed focus F2.0
this image is more noticable then the shots of the slate on this picture is what makes me think i have a depth of focus issue because the lens was fix focused
5.9mm wide angle fixed focus lens F2.8
this is the same shot and the other wide just after telecine
12mm-120mm lens F2.8 after Telecine
so hope this information is enough if not let me know what else you need thanks a bunch
to help these next shot are shots that were in focus i meassured these as well
