Flipping all the clips
If you select all the clips in your timeline you should be able to select all the clips and then drag and drop the filter in. I think the same can be done with your bin but I can't verify that at the moment.
Select your clip that has the filter already applied and hit cmd + C to copy it. Deselect then select all the clips you want to apply the filter to then right click on one of them and select paste attributes. Make sure you have only the filter check box selected in the pop up menu or you will paste more than just the filter.
If you have more than one filter applied to the clip you copied it will copy and apply all the filters to your clips. So choose wisely.
