Patryk_Rebisz
Today's scenario: using 5 HMIs (1.2s, 575s, 200s). Mix of mag and electronic ballasts. 1.2 starts visibly flickering from time to time (it's on mag ballast). Switched to electronic the ballasts keeps shutting itself down. Changing header - the same. Decreasing length of cable run from outlet - the same. Switching the heads - the same. So the issue must be with the outlet/power source. Still, out of curiosity, what would cause the light to flicker in those conditions?
