flicker/twitch on AVCHD export CS4
ncantrel
I am working on a project in cs4 and have run into a bit of a snag. When I export my final project into an mpeg, or any format for that matter, there are flickers/twitches that happen at the beginning of some clips. I have tried numerous different formats, field options, and have replaced the source files in the project. I still seem to get the same result. The flickers/twitches have happened at the same spots until recently when they seem to be more random. These issues only appear on the export and do not happen while I am working in premiere. I have included some screen shots of my source footage settings, sequence settings, export settings and system info. I am also including a link I found in another forum that has a video that exemplifies my issues. http://www.dvinfo.net/forum/adobe-creative-suite/483794-wedding-export-flicker-help.html. If that link doesn't work I am uploading an example from my project that I will post shortly
The example in the other thread is a misplaced frame, or frame out of order
If you clear the media cache immediately before exporting, do you get the same errors ?
