Monglane
Here I am again with pixel aspect ratio-related problems...
This is my new predicament : I shoot my movie in squeeze mode with the DVX in order to achieve final output to DVD in 16:9. The thing is, I'll need to include in that movie an animation made with Macromedia Flash.
Now, because Flash is not a video program, the animations it creates have square pixels. Furthermore, since Premiere Pro does not accept Flash documents as source input, I'll have to export the animation out of Flash in .mov format, then import that into Premiere.
So, my question is, Do I need to adjust the dimensions of the animation in Flash *before* I start creating the animation ? In other words, make the animation 1024 x 576 (I'm in PAL-land) ?
Or should I not worry, work on a 720 x 576 animation and change the pixel ratio later, in PPro, with Interpret Footage ? I fear that, if I do this, it will not look right.
Any help or tip as to how to proceed as safely as possible will be greatly appreciated. Thank you in advance !
