I prefer the Impulz LUTs for their flexibility, color and tonality, but I still use the FilmConvert plug-in's grain.
I'm not much knowledgable into these LUTs, but it's kind of a preset right? Once applied, you can't really adjust them
Yes, but you will apply more correction in addition to the LUTs, right?That would be incorrect, you can adjust your image however you want, the LUTs are just starting points.
I've always been in favor of doing it with the available plugins rather than using pre-made presets and kind of copying others' styles.With the impulz being LUTS they are meant to be used in your color correction pipeline, whatever that is for you
I was wondering if anybody can help me...
I do something close to what you suggested: I start with Levels, Hue/Saturation and then I add a layer of grain and other adjustments as needed. But I was under the impression that if I'd use the LUTs, and make any more adjustment after, it would introduce some issues, like Banding did with the Technicolor Picture Style with 8-bit videos. Maybe I'm wrong.
I get the point. The way I see things is that your camera records with it's own gama curve (picture style) and then, you work from there. But the point is, that it's a starting point to do the color correction.I wouldn't say a Lut is copying anyones style, maybe in this setting its copying a film gamma curve or color- not a bad start IMO. Its no "magic bullet" though.
After Effects also does that. And it really helps with the whites to work in 32-bits mode.One of the benefits of working in resolve is making corrections in 32-bit floating point with YRGB colorspace- as log as your not already getting banding from 8-bit footage resolve should help you get the most of those bits you have.
I've never really been able to understand how Resolve works. The file extensions and how to load footage into it, how to export it and all...So I gave up, and I've been able to get decent results in AE since.Its worth trying resolve anyway, its free for the lite version and you can compare corrections in both premier and resolve to see what you like better.
Not a bad thing though. Same starting point for different cameras.Guessing Its just a pack of input LUTs to balance cameras together before grading.
Hi hunter. I use final cut 7 still and have the bmpcc in which I may hold if no one buys, but Im not interested in learning resolve at the moment so is it possible to use impulz with final cut 7?
some great free tutorials on youtube.
