V videoav Well-known member Sep 23, 2005 #1 I cannot open a project because Premiere says its damaged. What should i do?
egproductions Veteran Sep 23, 2005 #2 if you had the autosve option checked when you were editing you should have some archived projects in the specified folder probably a folder with the folder that your original project was saved
A Averdahl Well-known member Sep 23, 2005 #3 videoav, if you dont have auto save enabled you can try to create a new project and import the damaged project into the new one. Sometimes it works! /Roger
