i think some thing like the Goalzero Yeti 400 would be a better battery solutionI think it looks awesome. Just bought a Softpanels and am looking at the Aputure 120t bi-colors as well but this light could be great w/the fresnel attachment!
Just wish it had a simpler battery solution than the power stations. After you buy the station and 4 V-mount bricks, you're looking at $4k+ just to power it via battery. Yikes!
the 400 can and the 1250 can....it is of course a different solution (you can't just pop on another V mount) and the question is how long the light will run on one but i don't see a reason why it won't....it will run microwaves and refrigerators.....you can also hook up a chain of yetis.....i have the 1250 and it will run anything but it is big and heavy....thinking of getting the smaller 400 to run a light like the M1 or Q1000 for an hour or two, which is all i need....Can the Yeti power 300w?!
hmmm....check with goalzero....their website says 12V but it says the same for the 1250 and i know that that will run the M1....both have inverters, not sure if the 400 has a pure sine (the 1250 does) ....after reading over the yeti specs it does say that longer draws over 300W might cause a problem with the inverter.(overheating?)...i believe the M1 at full power runs 320W....The M1 requires 48v. Yeti 400 has 12v out.
i had the same answer.....the yeti is not a industry known item....both goal zero and fiilex will answer phones btwI might. Need to get the M1 in to test it first and then I'll decide. The Hive Wasp is also intriguing, though a bit pricier but has high color accuracy and is super powerful.
I emailed Fiilex about battery power and they rec'd Block battery and Blueshape as the only two companies that had ready-to-go power solutions for the M1. I'll email them and ask about the Yeti also.
