Jason Adams
Section Moderator
I don't know if this post should go here. It has been sometime since I worked in AE so I don't know if this applicable to AE users, but there is no dedicated Combustion forum.
I found this on VFXTALK.com it is a great resource.
Greetings:
Most Combustion users who move their video files between
editing applications such as Discreet edit, Premiere, FCP, Avid,
etc. may at some time run into field problems, where their
video may appear with visable field/scanning lines..
(I know, I just did !)
Therefore, I am posting the below List of Video Standards,
with their related FIELD ORDER for reference...
Reference List: FIELD ORDER of Video Signals........
D-1 PAL -Discreet edit* PAL
Frame size: 720 x 576
Frame aspect ratio: 4:3
Pixel aspect ratio: 1.067
Frame rate: 25 fps
Field order: upper field first
PAL Video Frame size: 768 x 576
Frame rate: 25 fps
Field order: lower field first
PAL-DV Frame size: 720 x 576
Frame aspect ratio: 5:4
Frame rate: 25 fps
PAL-DV Widescreen
Frame aspect ratio: 16:9
Pixel aspect ratio: 1.422
Frame rate: 25 fps
NTSC-DV Widescreen
Frame size: 720 x 486
Frame asp. ratio: 16:9
Pixel aspect ratio: 1.2
Frame rate: 29.97 fps
Field order: lower first
NTSC-DV Frame size: 720 x 480
Frame aspect ratio: 3:2
Pixel aspect ratio: 0.9
NTSC D-1 - Discreet edit* NTSC
NTSC Frame size: 640 x 480
Field order: upper first
NTSC Full Frame size: 648 x 486
HDTV 720/30p Frame size: 1280 x 720
Frame rate: 30 fps
HDTV 1080/24p Frame size: 1920 x 1080
Frame rate:24 fps
regards,
Jack Pfeiffer
Author: "Combustion v2: The WebWarriors On-Line Guide"
see http://www.mci.dk/combustion
Greetings:
Frame rate: 25 fps
Frame rate: 25 fps
Frame rate: 25 fps
PAL-DV Widescreen
Frame rate: 25 fps
NTSC-DV Widescreen
Frame rate: 30 fps
Frame rate:24 fps
regards,
Jack Pfeiffer
