MatthewC
Few questions.
1) I saw that when your time remapping you can use a graph and by dragging on yellow lines, you can change the smoothness/velocity of the transition between keyframes. Yet whenever I go to the graph, I see the yellow keypoints and can move around, but there are no yellow lines overlaying my keypoints that I angle for velocity, etc. Where do I find these?
2) How do you get audio in AE? After I exported my clip with RAM preview, the music worked on the file being played back. If I do a normal render, the exported file has no audio
On that note, how do you enable audio when RAM previewing? It's got a mute button but its not clicked. I'd love to hear something when just previewing footage.
3) What's the best way to go about with using Premier Pro and AE together?
I was exporting a single clip from Premiere Pro, importing into AE, then exporting and reimporting again. Is there any easier way to do this?
Also, I got my first test up here: http://my.videoegg.com/video/dhxTeH
If I can get question 1 answered I can smoothen up the transitions a bit.
