fcp5 capture issues
humberto
hi!
we are trying to edit some footage shot with the hd100 and we get 59.94fps instead of 29.97 does any one know whats happening???
apretiate your help because we have a deadline comming very soon.
Same problem in IMovieHd and two systems
the problem is that when I try to edit or play it it plays at double speed, I have tested this with two differet mac G5 systems and the results are the same, and another thing in one of the two systems I tried using IMovieHD to capture an play and still have the same problem , double speed playback, and the settings are the default hdv capture settings
720 30p ,
thanks, i dont know if any one else has experimented a similar problem with the camera and FCP5
I don't know the answer right now. Try capturing via GCAM. It makes quicktime files so you could just copy it in you FCP timeline. You can download it for free (only 50k) and it works great. When having difficulties, this might be a solution for the time being. When you capture, Pay attention to the settings(frame size). The default is 620x480. So put it on 720x480
Hope it helps
