Having converted from Vegas to FCP, I'm finding the interface on FCP really clunky and slow to use. Things that are quick to do on Vegas, take longer on FCP. I've been working on FCP for quite some time now, and a complex project takes more than twice as long to create in FCP than in Vegas. I'm wonderin if anyone else has had the same experience, or if there is something I'm missing? FCP is supposed to be an excellent program, so I'm wondering if I'm doing things wrong somehow. (But that in itself is another niggle- Vegas is intuitive, I never had to read the manual, where as FCP I had to read the manual just to get started. I don't mind learning curves, as long as it's worth it, but I've found that doing things in FCP is so much slower than Vegas, to the point where time adds up.)
Some specific examples:
You're located on a point in an event, and decide to split it at that point:
FCP: 1. select the razor-blade tool (or press B) 2. zoom in (command + ) 3. click exactly at the same point where you're located.
Vegas: Press S
You would like to erase audio from the selected event:
FCP: 1. move the mouse to the left part of the screen 2. click the lock icon for that video track 3. move the mouse back to the event 4. click the audio 5. press delete
Vegas: 1. press U 2. click the audio 3. press delete
You would like to cross-fade audio tracks that overlap by 1 second (to avoid clicks)
FCP: 1. Click the cross-over point between the events 2. right-click 3. select 'cross-fade' 4. There is no easy way to then customize the fade
Vegas: 1. (cross fade is automatic) drag the cross fade to customize it.
You would like to edit video and audio manually, independently
FCP: 1. Move the mouse to the left hand side of the screen. 2. Press 'lock' on each audio track one by one, until they're all locked. 3. edit the video events as you wish 4. Move the mouse to the left hand side of the screen. 5. Press 'unlock' on each audio track one by one, until they're all unlocked 6. Press 'lock' on each video track one by one until they're all locked 7. edit the audio events as you wish 8. Move the mouse ot the left side of the screen 9. press 'unlock' on all the video events one by one. 10. If you wish to edit audio or video events again, repeat the above process.
Vegas: 1. Press Ctrl-A 2. Press U 3. Edit audio and video as you wish.
You wish to create a fade out
FCP: 1. Select the Pen tool 2. Click on the video event where you'd like the fade to start 3. Click on the event where you'd like the fade to end and drag down to zero 4. Click on the audio event where you'd like the fade to start 5. click on the audio event where you'd like the fade to end and drag down to zero.
Vegas: 1. Click the edge of the event and drag the fade across
The above are just some basic editing examples. When you're doing a complex project, since the time to do little tasks is more than doubled, it takes a lot longer to edit a project in FCP. This time adds up. I know a few FCP gurus and Vegas Gurus, and the FCP gurus take much longer to do the same project in FCP than the Vegas guys do. I'm wondering if this is just because my Vegas guys are faster - or if it's something to do with efficiency of Vegas interface versus the FCP interface.
It's a shame that FCP doesn't have Vegas' interface, as I prefer the output quality & preview quality of FCP. (Vegas output tends to change colours / contrast). But overall, since I have used Vegas and FCP, I'm finding simple tasks on FCP unnecessarily time-consuming. It's a big difference; we're talking less than half the time to do the same project in Vegas. I just wish Sonic Foundry still ran Vegas as Sony are doing almost nothing for it. Over-all, I guess I'm going to be returning to Vegas, simply due to the time to do basic tasks.
Last night I realised that I was allowing FCP to make decisions for me, as opposed to making creative decisions myself. I was choosing short-cuts to get the project done, and at that point I realised I had to go back to Vegas.
It confuses me though, because FCP is expensive. You'd expect the interface to be top notch. Has anyone else had similar experience or am I missing something?
Vegas: Press S
