I'm evaluating PP CS5 for several reasons. The first one is that I'd like to avoid the transcoding time required for DSLR footage in FCP, though I know I'll still spend some time logging and organising the footage in PP prior to start of editing because it saves time later.
However, there are somethings that are kinda bugging me and I can't figure out. Maybe some PP experts know how to do this stuff?
• Anyway to take two mono tracks (which were really L+R) and turn them in to a stereo pair? I want to send them to Soundbooth as a pair, and not separately.
• Anyway to change the color of the audio (or video) in the sequence timeline? I like that the video is blue and the audio is green in FCP. It helps me view the sequence more easily...
• Anyway to re-join clips (called Join Through Edit in FCP) that were cut by mistake, but are still on the sequence timeline next to each other? While undo works, if you are two or three hours later you can't undo
Any way to tell that the clips are actually adjacent frames of the same clip? FCP shows this, PP doesn't seem to.
• Any way to add a cross fade between clips without having to dive in to the effects panel? FCP you just right click on the edit point and select Cross Dissolve.
• Anyway to take footage and drop it on a sequence timeline at the clip's time code position automatically? FCP you can use Create Multiclip Sequence and it drops all the clips from mulitple cameras on their own track and at the position of the clip's timecode. This makes it easy to see all the footage from a multi camera event placed at the correct time in a single sequence.
• Anyway to tell PP to take a sequence offline, or to bring the footage for a sequence online (reconnect media) without having to select those clips in the browser? Handy for only bringing online the clips actually used in a sequence.
• On a test project I had, the A1 selector seemed to become locked to audio track 5. Any idea how that happened and how I can unlock it?
Oh, there are more, but these are some of the basic ones.
