thunderMex
I have a new MacPro and the Final Cut Suite including Final Cut 7.
A month ago when the system was delivered I had to start editing without an eSata connection to my 6 TB external hard drive unit because the eSata input was apparently defective. The drive was connected with Firewire 800 for the time being until the new unit arrived with a working eSata cable socket.
The 6TB -- 4 X 1.5 TB drives-- were not partitioned, simply made one drive called "Video".
Today the technician showed up with the exact replacement external hard drive from Sonnet and made an exact copy of all the files from my existing "Video" to its new mirror also named "Video".
I went into FCP system settings and re-set it to work with the new eSata connected "Video". I also used Media Manager to save a Copy without compression of all the used media files in my existing open project into newly named folder on my new eSata external hard drive also named "Video". Supposedly I had two identical "Video" drives otherwise.
But now my projects all seem married to the previous "Video" Volume where they were originally saved. If I start up FCP without the previous "Video" mounted I cannot open up my most recent Autosaves of projects or the deliberately named .fcp files. FCP, which is installed on my internal system drive, tries to load up the last project and I have to keep force quitting it because it gets about 32 to 36% status on the loading files and then can go no farther. It will sit with the spinning beach ball forever.
When it does run because I keep my previous "Video" external drive open through the Firewire 800 connection I see that I "sucessfully" re-set FCP to use the new "Video" as the place for capture and scratch and render files. But FCP even when I have the original hard drive unit unmounted can not read project .fcp files -- unable to load the media, apparently.
The only difference with the new mirrored RAID is that it uses S.M.A.R.T. , which was disabled on the Video volume running on Firewire 800.
Tomorrow they want to send a courier to pick up the original volume but I cannot get FCP to work with the eSata duplicate Volume.
Any tips out there?
If I CAN open up a copy of the project .fcp from a couple of days ago it will not load the timeline!
If I shut down the new eSata "Video" so that it does not mount and return to starting up my MacPro with the previous "Video" unit connected by Firewire 800 I can get back all my projects and timelines and media.
Thanks for any relevant help.
Any tips out there?
