FCP HVX Frame drops...
Indy
I'm trying to capture from tape with my HVX using FCP. Everything appears to connect correctly yet once I start to capture i.e. within a second or 2 it stops with the error "frames dropped" or some such.
Has anyone any ideas on what I can do to fix this issue? i'm using a 17" Powerbook 1.67 and the latest OS X and FCP versions.
Cheers
Indy.....
Jim Carswell said:
How fast is your hard drive 5400 or 7200?
Its the standard Powerbook 5400.... but I've also tried this using an external Lacie d2 FW800 but still getting the same problem :(
BenB said:
Try starting your capture a couple of seconds into the tape.
Are you using Batch Capture?
I'm using 'Capture Now' but even going a few seconds/minutes into the tape I'm still getting the dropped frames error.
Indy....
Clean your tape heads. What is your capture setup? Be sure it's set to DVCPRO-HD FIREWIRE. Get FCP Preferences Attic (freeware) and trash your FCP preferences.
