FCP footage on a PC
watson
I just sent a client some footage on a harddrive. It was NTSC-DV footage captured in FCP. I thought as long as they have the newest version of Quicktime they would be able to view it on their PC, but they say they can't. Is there a codec they can download so raw .mov NTSC files will play on a PC?
Basic NTSC DV should play on any PC pretty much. They don't even need the latest Quicktime. What happens when they try to play it? Does it error or is it scramble or does it say they need a codec? Were the movies self-contained? If the files they have are extremely small then reference quicktimes may have been made instead of self contained.
Best,
Andy
Its files that i captured, using FCP's NTSC-DV set up. The files should be self contained. Of course, they just say its not working, but not giving me any other details. (ugh clients!)
I'm not familiar with reference quicktime, how small are you talking about? A lot of the clips are between 30 seconds and a few minutes.
Were the files saved in a 422 pro-res format? I have had that issue. See if you can't find what their compression format is.
Umm, other then in finder where can i find that info? In the viewer window in FCP? HVXOU where you able to work around that? Is that codec available to download to for windows?
problems solved! stupid client. Told them 10 times to make sure they had the newest version of quicktime and of course thats what it was.
