FCP Color Correction
Cale Glendening
Sorry if this doesn't meet the guidelines, but I was just wondering.
If I have a clip and splice it up, or have some other clips I want the same color correction for, is there a way to use the same settings for each clip instead of doing it by eye to match them up?
I am using the (Color-Correct 3 way in video filters).
Cause matching them up is a pain, is there any way to drag the settings into the clips you want the same or what? Thanks guys!
Once you set the effect on the clip... you can drag that clip's filter to any other clip.
There's also arrows on the visual of the filter that will 'send' it one clip forward or two clips forward (back too).
CaptM
Another easy way to do it is copy one clip and then right click on another clip and go to paste attributes and then select filters.
