I use a digidesign Mbox2 because a friend of mine had one on hand. It works most of the time for voiceovers, sometimes it's really hard to make FCP's voiceover tool recognize the Mbox2. One thing that I don't much like with my setup is that you cannot use it to monitor audio, only as an input device. I'm probably going to find a different solution that works all the time. The Mbox2 is usb I have no experience with the Mackie ONYX 1220.
Do some digging my friend and you will see how you can use the Mbox to monitor audio. Also you can import quick time movies into Pro Tools, so you can do your voice overs in there while still looking at your clip :happy:
It looks like Mackie upgraded the Onyx line. It's now called Onyx-i and all of the mixers come with Firewire already built-in. Final Cut Pro support is listed.
Onyx-i product page
You can find some reviews on the product pages for each mixer. It's a new product so there's not much out there yet. I imagine that they work in a similar way to the old Onyx misers with the Firewire card so you can look for reviews of those models. Also check out the manual (it's available as a PDF on the product page for each mixer).
From what I've read, the Firewire interface lets you record each channel strip pre-fader, either pre-EQ or post EQ, as well as the finished left/right mix. This way you could use the mixer as a straight interface and record into your computer and mix later in software, mix on the hardware and record the final mix to computer, or both.
It's not a control surface so you can't use it to control the levels of your audio tracks once it's in Final Cut Pro. If you want to do that, you need something like the Mackie MCU Pro or Euphonix MC Mix/Control. Or you can go with something like a Tascam FW-1082 which is both an interface and a control surface.
If you are mainly looking for an audio interface and plan on mixing on the computer, you might want to check out some of the "mixer-less" audio interfaces from the companies I mentioned above; Apogee, RME, MOTU, Focusrite, Metric Halo, etc. Check if the product is support on the Mac and you are good to go.
