Hello! I'm just putting the finishing touches on a 30 minute short film shot on the DVX.
Overall, the edit looks and sounds great, except for a few faint "clicking" or "popping" noises that Final Cut Pro creates for no apparent reason once the audio tracks start getting layered up. Most often, these strange clicks appear at the point where a cross fade begins or ends.
Also, when I adjust the volume of my music files to increase or decrease over the course of a scene (by using "envelopes," not cross-fades), playing through the whole scene sometimes results in sharply abrupt changes in volume instead of the steady gradual ones I put in. Oddly, when I play the scene from a point closer to the change in volume, the shift plays normally.
Are these just weird little bugs that will disappear during the export, or will they remain in the finished movie? I've noticed this stuff before on some of my smaller projects and have either managed to maneuver around them or just live with them... But this is a significantly larger project that many people have put a lot of effort into, and I want to make sure the finished product is as flawless as possible.
Any ways of dealing with this? I'm pretty sure all the audio files I've imported are in either .AIFF or .WAV format, which FCP can handle if I remember correctly. And these are definitely not problems with the original source audio-- they play fine when first put in the timeline, but too much messing around seems to result in annoying bugs. Help! What should I do??
